Head/Cam/Injector Combo Suggestions
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
i have a eagle 383 stroker kit .060 0ver on a 91 L98 block
I also have a modded Lt1 intake from john.
I want a 500 + lift cam that will compliment the lt1 intake as well as injectors and heads
thanks
thanks
Something in aluminum, chamber in the low 60's cc, intake port around 200 cc, at least 2.02 int and 1.6 exh valves.
http://www.protopline.com/123400000a.htm
Anywhere from 24 lb to 33 lb on the injector depending on what you plan to do about the chip and fuel pressure.
The camshaft should suit the transmission that you'll be running.
Once you pick the camshaft you want, then take about 10* degrees off the intake duration if you run an automatic.
darwinprice
17
10-11-2015 11:51 PM
