Will 2003 Mustang GT 22lb fuel injectors work with TPI?
Car: Trans Am
I found a good deal and the seller says they will work on fbodies with TPI. Will they, and what else is needed like new retaining clips or anything like that?
What other cars fuel injectors will work with TPI?
Car: Trans Am
Try and search "mustang injectors" and "mustang fuel injectors" and "injectors from mustangs" and so on and tell me what you get besides my thread. In other words I've tried.
But there wasn't a part number but here is the link. Let me know what you think.
http://cgi.ebay.com/ebaymotors/ws/eB...3ARTQ%3AUS%3A1
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
same ones I have, thay work better than I thought, thay work grate. got mine at FiveOmotersports at about $200 shipped (brand new)
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Do NOT buy injectors off of ebay,,, many of us have been screwed that way. You have no idea what you are really buying. Getting 8 good injectors for your engine is extremely important. How could you leave that up to a stranger.
Only buy injectors from a well known business that stands behind what they sell.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Simple. Ask for the part number, it should be on the FI body. I typically see the 24lb blue top ones though, and a good point was made with regard to ebay injectors. :shrug:
Car: Trans Am
True, true about the ebay thing. Well here's the thing, my 19's work fine. So I was just going to keep them and get a custom L98 chip only change the injector value to 19lbs.
Car: '87 IROCZ
Engine: 395 ZZ4
I did not realize that you have a 350 now and want to use 19#/hr injectors.
19s will not flow enough fuel for your 350 unless you install a AFPR and set the fuel pressure at about 56 to 58 psi.
Do yourself a favor and buy the FMS 24#/hr injectors, and also install an AFPR. These injectors will flow from 24#/hr at 39psi on up the 29#/hr at 58psi. These injectors will give you plenty of room to grow on Hp.
I am still running my FMS 24s even in my 395 stroker motor. I had used them in my factory 350 with lots of mods.
Like I said above, its very important to get the right injector and good reliable ones also.
1 Post
Car: 1992 B4C 1LE
the ford 22#ers are pink I think.
I ran the blue top 24's with no problems.
9192camaro
16
02-03-2019 12:21 AM
