Vaccum leak, easy solution to findin it?
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
i hear alot of people use foam or somethng, but i dont where id put it in/ and what to buy, any help here?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I used a small container of propane gas, just start the engine, get an idle, and open the nozzle. Move the nozzle tip around, if the RPM suddenly rises, you found your leak.
1 Post
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Quick start fluid works good too. I always have carb/tb cleaner, propane and quick start fluid around. Which ever one I find first is the the one I use.
bubbaz28
09-18-2015 02:09 PM
