need pic of evaporative canister from TPI
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Can someone please post me a pic of your Evaporative canister from a TPI set-up? My carb set-up does not have a purge solenoid and electrical connections on the canister itself. I want to know exactly what I am looking for when I go to the bone yard on Thursday morning.
Tony
Tony
Car: 1986 trans am ws6, 66 grandprix
Engine: 88 iroc 5.0 tpi
Transmission: 700 r4 built by rocky pirrone
Axle/Gears: 327
i put a canister from a 1986 2.8 mpfi firebird on my 1986 tpi trans am and it works fine
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Originally posted by Vader
This is the TPI version for 1986:
Car: Take
Engine: Your
Transmission: Pick
Carbed versions used a Ported Vacuum source to signal the Canister Control Valve. Ported Vacuum is vacuum off idle. The port sits above the throttle plate so that there is no vacuum when idleing. The whole point was to prevent the canister from purging when at idle, due to the low volume of air.
On fuel injected cars, in uncommon to find ported vacuum because the ECM just used an electric solenoid. You can still use the carbed canister, just use an external purge solenoid on the "purge" line, and let the TPI computer control it.
Car: 86 T/A
Ghettobird52
07-05-2024 11:18 PM
Sanjay
08-12-2015 03:41 PM
