383 TPI Camshaft
Old 10-05-2005 | 09:02 PM
Mitch_Cox_kc's Avatar
383 TPI Camshaft
I'm building a 383 TPI and am going to us the Comp Cams
Part Number 08-502-8
Grind Number CS XR269HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.495 0.503
Duration At 0.006 Tappet Lift 269 276
Valve Timing At 0.006
Open Close
Intake 26 62
Exhaust 74 22
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.33 0.335
Lobe Separation 112
I'm using 24 lbs injectors and factory chip, headers
What do you guys think.
Mitch
Old 10-05-2005 | 09:11 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
There is even a better one if your heads can handle it. Try 08-466-8. It is designed specifically for fuel injection cars. If not go for the one you have.
Old 10-06-2005 | 10:52 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Peronally I think that is a little small, try the Crane grind they put in the ZZ383, 222/230 .508/.528, I ran it in a 350 with 9/1 compression and it came on like a frieght train at 3500 rpm's up to 6500, low end was a little soggy but that is because of the 350 ci and low compression, with a 10/1 383 it would kick but, I am actually going to re-install it a 383 in the future.
Old 10-06-2005 | 09:42 PM
My heads could handle the cam but i'm not running a roller block. I have this tpi setup in my 62 Nova.
Thanks for the infor guys.
Mitch
Old 10-06-2005 | 10:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run the lingenfelter 219/219 560/560 112 cam in my 383 with Large Tubed runners. I like it
Caspar
06-19-2016 11:19 PM
Reddeath210
10-06-2015 08:20 AM
gta90
09-15-2015 04:00 PM
85Iroc-Z
08-13-2015 01:58 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 383 TPI Camshaft
