timing?
Old 09-27-2005 | 07:19 PM
chikn305's Avatar
timing?
What should the timing be on the scan tool in 1st, 2nd, and 3rd gears at wide open?
Old 09-28-2005 | 04:02 AM
Z69's Avatar
Z69
That would depend on a whole lot of things.
None of which you listed.
Old 09-28-2005 | 07:15 AM
chikn305's Avatar
what other things do you need?
Old 09-28-2005 | 09:11 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What engine and tranny combo?
What rpm where u at?
What was your MAP or LV8 at the time?
Was the car up to operating temp?
Where u experiencing knock at the time?
and on and on :-)
later
Jeremy
Old 09-28-2005 | 12:57 PM
chikn305's Avatar
Here's the deal when I look back through the data the timing through 1st gear was 15 degrees 2nd was 22 degrees and 3rd was 32 degrees with 0 knock. All data was collected on the dragstrip at wide open throttle spraying a 150 shot. I'm wondering if the timing is right it seems to me that it should go to full timing sooner than 3rd gear. My combo is 305 tpi with big mouth base, edelbrock runners, portwed plenum, lpe 211 cam, ported sr torquers, 2800 stall edelbrock headers, 150 shot of nitrous, and custom chip
Old 09-28-2005 | 01:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by chikn305
. . . and custom chip
Nothing to do with DIY PROM, moved. . .
RBob.
Azrael91966669
25
06-20-2017 04:04 AM
bamaboy0323
09-03-2015 06:07 AM
Feffman
Mid-West Region
08-13-2015 07:12 AM
Feffman
08-13-2015 07:11 AM
Thirim
08-09-2015 06:19 PM
Quick Reply: timing?
