How Many Miles On Your Tpi
Car: 91 formula
Engine: 350 tuned port. bolt ons
yup lets hear how many miles you have on your tpi. when i bought my formula in july of 2002 it had 109k miles on it and now it at 136k. not bad i guess.
70,000. Still running very strong. Not even any smoke on start ups.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
193000 miles. Original engine and trans, rear diff has been replaced. (carrier bearings where whining...) I have replaced the valve seals, valve cover gaskets, and that is it for the oil system. I do not burn any oil between changes.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
95,000 and running strong, tad bit of oil burning on startup, but its minimal (bad valve seals)
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Originally posted by §teve
bout to hit 118k ive put 15k on it.
Never seen smoke...
Never seen smoke...
1 Post
Car: Pair of 92 Z28s
Originally posted by DanTheMan_smlk
so you gonna pull the engine if it comes down to it?
Originally posted by luke4907
except from your tires or in your rear view mirror as I can see by your avatar or whatever those pictures things are
Car: 1991 TRANS AM GTA
Engine: 5.7L TPI
Axle/Gears: 3.23 Posi
Well its been a while b/c I can usually find my answers so thanks TGO!!Anyway, I have 266k on the original motor.
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
153,000 with a little tick and still on the 15.0@90 mark. Waiting on it to croak before the 350 swap. Hopefully itll be awhile.
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
158K and having a little fuel pump problem right now. Just bought the car. A TBI 305 RS parts car I just junked had 386K with a knocking motor, figured that was pretty good !!
1 Post
so if you never find the source of the leak you will just let it drip forever and make a mess of the car?
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
no clue.
Car has over 150 on it, but it's got a different speedo for abour a year, and I never cared to take note of the mileage, engine was replaced at some point before I owned it.
My old 87 IROC has around 220K on it, and still running stronger than ever. I only put new rear main, oil pan and valve cover gaskets on it, which stopped pretty much all the leaks
#46
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
STILL RUNNING
I got 197,000 miles on mine and she's still running strong. I have already changed the injectors, transmission and rear diff. Suspension is next on the list.
#49
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
My 89 formula had 97,000 on it when I sold it, well the body did anyway, drive train had less than 30,000 on it.
My 86 Z28 has 124,000 on it and still going.
#50
Car: 91 formula
WOW did not know this TPI last so long. and they say honda and toyota last long. and i say do you really thing GM makes cars so they will brake down fast then any toyota or honda. think about it
