Cooling fans...help
Old 09-04-2005 | 09:19 AM
LoudmouthSS's Avatar
Car: 2002 WS6 A4
Cooling fans...help
MY cars cooling fans wont go on. I think my right fan may be dead, but my left i know works...i put in my code reader and put the key in the on position and the fan comes on. Ive checked the relay and ground...there both good. I changed the thermostat, coolant temp guage switch, fan switch and coolant temp sensor...nothing
any other suggestions?
Old 09-04-2005 | 06:53 PM
Car: 2002 WS6 A4
anybody?
Both fan motors are good, and when i turn my ac on, the fan thats supposed to go on doesnt either.
Old 09-04-2005 | 07:33 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
For starters, pull the connectors on the motors and verify power is going to them when they are supposed to be on. You can ground the relays to force them to come on. Do a search and you can find the wiring diagrams for both fans. How hot does it get without a fan coming on?
Old 09-04-2005 | 09:50 PM
fireball451's Avatar
Car: 91 Z28, 91 Z28, 92 Z28
Engine: LB9, LB9, L98
Transmission: T5, T5, 700r4
Axle/Gears: 3:42, 3:42, 3:23
Pull the connector that hooks to the fan switch in the passenger side head. Tough it to ground with the ignition switch on. This will make the fan turn on. If not, the the fan motor or relay is bad.
Old 09-04-2005 | 10:16 PM
Car: 2002 WS6 A4
it gets to 260 if i let it...
Both the fan motors i know are good...and i know the relay is getting power..
How do i ground the wire that goes to the fan switch out?
Old 09-04-2005 | 10:30 PM
Unplug the fan switch. Touch a piece of wire to the connector and touch it to the frame, motor, suspension, or even to the side of the fan switch itself. The switch heats up and makes ground to complete the circuit.
Did you happen to replace the fan switch?
If you have, did you use teflon tape on the threads?
You should not have. It is a dry seal.
Can not have anything dirupting the ground.
Old 09-05-2005 | 10:34 AM
Car: 2002 WS6 A4
ok ill try that...yes i did replace the fan switch and no i didnt use teflon tape, but there was stuff on the threads that as it was screwed into the block began to bunch up outside of the hole in the block..
Old 09-05-2005 | 10:39 AM
Car: 2002 WS6 A4
ok i tried grounding it...alls i heard was a clicking noise from the left side of teh egine on teh firewall
Old 09-05-2005 | 11:08 AM
That is the relay. Sounds like it is working.
Do you have a wiring diagram for the car?
Looks like you are going to need a meter and start checking the wires.
Linson
09-25-2021 07:55 PM
sheachopper
07-31-2019 11:27 AM
oil pan 4
Fabrication
10-06-2015 11:56 AM
ndndndnd
09-28-2015 08:00 AM
64goatman
09-09-2015 01:09 PM
Quick Reply: Cooling fans...help
