86 T/A still at the shop
Old 09-02-2005 | 08:03 PM
vette&T/A's Avatar
Car: 86 Trans Am
I don't know if anyone remembers I posted a while ago about my 86 TPI not idling, well the shop still has it, they've replaced a lot of stuff, good thing for my they aren't going to charge me any labor. They're going to take the car to the dealer and see what happens then. It appers that the previous owner knew there was a problem, and new how to fix it so it wouldn't act up for a few days. Well the temporary tag has already run out, so if the dealer can't fix it without major costs, I'll go to get the emissions, and when it doesn't pass, this guy will be getting a phone call to either he needs to fix it or give me back my money.
Old 09-02-2005 | 09:09 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Well it cant be that hard to figure out, any shop that has mechanics worth a squat should know whats wrong. If it won't idle I'd suspect the IAC is acting up. I'd check it, and the connector/wires to it. Check the fuel pressure by simply hooking up a guage to the test fitting. Check engine light on? Pull the code or hook up a tech one and read the data while the veheichle is running.
Old 09-03-2005 | 10:09 AM
vette&T/A's Avatar
Car: 86 Trans Am
I don't know exactly what the shop has done, I do know that it is still throwing the MAF code, and they've used 3 different ones. I would think hte dealer would know for sure to check the fuel pressure and everything else, it does run great at anything other than idle though.
Old 09-03-2005 | 04:38 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.73
its your relay should be up by your firewall on the drivers side your maf is not bad this is the maf relay that gos bad i got mine from NAPA auto here is the part number 912210 mine is a 88 so might be different now there is a couple of these relays under the hood all take the same part number but mine was the second one over on the firewall good luck
Old 09-03-2005 | 08:04 PM
vette&T/A's Avatar
Car: 86 Trans Am
thanks, I can't talk to them until tuesday now, but I do remember them saying someone screwed with the relays, don't know why it didn't dawn on me before but you would think they would want to replace that. hmmm. maybe I won't take my vette there.
Ed1LE
09-30-2018 09:14 AM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
2012sergen11
10-13-2015 07:38 PM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
IROC ZELLER
09-29-2015 03:00 PM
Quick Reply: 86 T/A still at the shop
