What to media to bead blast my TPI
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
This TPI setup I have is a bit oxidized. What media should I use to bead blast it so it'll clean up nice?
Thanks for your input in advance!
Would black beauty be too abrasive?
If so what should I buy? I know there are different types you can purchase.
It all depends on the look you're going for. If you want a bright shiny finish, use glass bead. If you want a dull, dry finish, use skat magic or screened play sand. You must remove the four bottom plugs in the lower intake. If you don't, you'll pack blasting media in the bottom of the intake.
I personally like the look of steel shot. It's very abrasive, pits the aluminum, and leaves a dark finish. This is what Street and Performance uses. It produces the same finish as the Corvette TPI intakes. I have been advised that any media containing metal will cause the aluminum to show rust. I can't confirm this from experience.
That is exactly what I wanted to know. Gives me a starting point for sure. I have a 3 runners that are dented up I can use to test on.
Thanks!
Thanks!
Fast355
12-02-2016 06:33 PM
1992rs/ss
16
01-28-2016 09:58 PM
LT1Formula
20
11-14-2015 12:02 AM
Sanjay
08-12-2015 03:41 PM
