Who makes a good 255 lph intank fuel pump?
Car: 1987 Formula 350
Engine: TPI 350
Summit sells a Granatelli 255 lph stock replacement fuel pump for $126. Is there something better out there for about the same price (or less). I'm looking for a simple install with NO additional wiring etc. If you guys could post part numbers and or links to places that sell the recommended pump that would be great! --Dan
Is the Granatelli pump a nice unit?
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
walbro..
i happen to have a 255lph walbro that i only used for 2 months.. too powerfull for my needs.. has the plug in pigtail you need.. you just need a new filter bag to put on the end of it...
70$ shipped... PM me if you want it
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
No, but it can cause the pressure to rise up under low fuel demands since the regulator might not be able to handle the return flow. I have one with my holley tbi and it wasnt a problem.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Heres a secret:
Just by a Walbro and save $$$
Granetelli among others rebags/boxes them and sells them for more than if you just find a deal on a regular "Walbro" pump lol
later
Jeremy
later
Jeremy
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
In case no one mentioned it before....WALBRO!!!!
This is where I and I'm sure many others got theirs:
http://www.autoperformanceengineering.com/
beachrodder
08-25-2015 08:05 AM
AkDrifted
08-17-2015 07:45 PM
