'82 Vss
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
'82 Vss
Hi all,
I'm working towards putting a 305 and TPI in my '82 TransAm from an '89 Camaro. In '89 Camaro's still used a cable on the transmission for the speedo. My car has a VSS on the back of the speedo, and I'm wondering if I can use this? If not, can I use the speed sensor from my B&M lockup converter kit?
Car: 1982 Z28
I used my '82 VSS output when I swapped in TPI, just had to change one setting in the TPI binary (VSS=Optical) and it was a happy camper.
Default setting on both the MAF and Speed Density binaries I used for my base was VSS=Magnetic, which expected a 4K pulse/mile output and wouldn't have been happy with the old optical VSS output.
Car: 1989 Trans Am
Oh that is good news! What parameter did you change? I had a look at a bin using WinBin but didn't see it. I presume it's a flag?
Car: 1982 Z28
If your '89 setup has a cable-driven output off the transmission, you don't need to change anything in software. Just hook it up to your speedo and pin the speedo's VSS output to the ECM.
TMZIrocZ350
10-07-2015 12:09 PM
