Vacuum valve off plenum
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
The two vacuum fittings that come off the plenum near the distributor. One goes to the FPR the other has a 3 inch long vacumm line the goes to what looks like a valve , two more lines
then run off this valve.
While adjusting my AFPR I managed to break the valve( or what ever it is). Can someone tell me what it is and a part # to go with
it.
This sh*t allways seems to happen on a friday night.
The B*tch is i just got the car put back together.
it.
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
It's a vacuum check valve. You should be able to find them at just about any parts store. You can make it driveable by just plugging the vac. port off the intake, but your vent controls and cruise won't work.
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The GM part number is 14056648. As TheGreatJ said, you can pick up a universal replacement at most part stores. Motormite 47150 should work in this case.
Ok... Kraigens does not care them. They have it as an "dealer only" item. It looks pretty strait forward.
Thanks for the part #'s. What is motormite?
Thanks.
It would be nice to have the vent controls working. It was 101 degrees today
Thanks.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
motormite=HELP, look in the "HELP" section, they used to sell them, also check in the HELP section at autozone.
Engine: 305TPI
While we're on the subject, can anyone me tell the the size vacuum line coming off the check valve that goes to the cruise control? I have 5/32" on there now, but I have references that show it as 7/32" to the tee and to the accumulator ball.
Thanks.
Thanks.
Got It...Napa had nothing under the gm part number but found it under motormite.
Back on the road. Thanks
I replaced some vacuum hose. Don't know what size it is. They took the part in back and brought out hose to fit it. sorry
Engine: 305TPI
I'm still trying to determine what size vac line that should be. I'm leaning towards the 5/32 being the correct size now.
Hotrodboba400
12-10-2019 07:07 PM
355tpipickup
09-13-2015 11:35 PM
