TPI distributor wiring
A while back I picked up a stealth ram. I have a 1986 ta tpi that this is going on. In the GMHTP article about their iroc they mention a wiring kit from accel to go from the in cap coil style dist to the remote style. I called summit a few days ago and they said this part is discontinued. Does anyone have one or know if someone else makes one?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Fuel Injection Specialties makes the harness, but you can make one as well, just need the connectors and some wire. or you can just change the connector on your engine harness.
http://fuelinjection.com/
Just give them a call and tell them what you are doing and they will get you the right parts.
I think I paid around $45 total for both harnesses, the adaptor harness and the dist to coil harness.
Sanjay
08-12-2015 03:41 PM
