Crane AFPR hitting plenum!?! help
Car: 89 Formy
Engine: 305--->TPI 350
Transmission: auto :(
I just got done with the 305 TBI -> 350 TPI swap and I think it is running rich because it bogs when accelerating from a stop and it smells rich. I think is caused by my crane AFPR that is tighten down quite a bit to get the plenum on. I'll try it get a pic on here. I had to tighten it down about half way to get the plenum on. I was wondering if anyone else a problem like this?
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Yeah,
everyone with a cran AFPR :-)
Either find a shorter bolt that fits, or cut the one it came with down.
If cutting it, run a nut up it first and try to cut it clean. then u can run the nut off and then use a die to clean up the threads.
later
Jeremy
later
Jeremy
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I found one at ACE hardware store that was perfect and kept the one from crane incase I needed to match another bolt to it later.
I don't know why crane makes the bolt that long.
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: Crane AFPR hitting plenum!?! help
how short do u go to? i dont wana make mine so short it wont make certain pressure adjustments know what i mean? so how long should the bolt be for it to still work but not hit the plenum?
also what diaphram do u guys use? the stock one?
2012sergen11
10-13-2015 07:38 PM
