TPI ZZ4 idling smooth, but hesitates??? HELP!!
Car: 1986 camaro
Engine: 5.7 HSR
Transmission: 700-r4
Axle/Gears: 3:42 auburn
the computer and chips are stock, the car has excellent power, but It idles as smooth as the stock 305 I pulled out!! other than a cycling up and down every few minutes, could it be a vacuum problem? I cant find any leaks,but at the intake manifold, I'm only getting 10-12 PSI of vacuum!! WTF, the timing is set at 8* adv, any less and it hesitates! I am currently looking into getting into chip burning,but I still think this car should run better than this!!!
, If you gas on it from a dead stop, and let off it will die! when you power brake it, and let off, it idles WAY down, then back up,
I have already tried readjusting the IAC, and the TPS, the car has a Brand new Bosch MAF sensor, and NO SES codes, any help would be greatly appreciated, thanx!!
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
u need computer tuning for that cam. 224*/236* dut @ .050
way to much for the stock chip
Car: 1986 camaro
Engine: 5.7 HSR
DO YOU THINK THAT IS WHY IT IS TRYING TO IDLE SMOOTH? BECAUSE i AM USING A FACTORY CHIP? i WENT WITH THE 85 VETTE CHIP B/C IT WAS INTENDED FOR A 350 tpi INSTEAD OF A 305, DONT GET ME WRONG,THE CAR RUNS LIKE A RAPED APE, BUT WITH THAT KINDA DURATION, IT SHOULD HAVE A LITLE MORE SOUND,THAN JUST SOUNDING LIKE IT HAS A MISS, AS SOON AS i PUT THE NEW MOTOR IN, THE maf WENT OUT, so i GOT A BOSCH REMMANED, iVE GOT A G2 INSTALL PLANNED FOR MY ecM ALONG WITH A BURN 1 PROM BURNER, i FIGURE, i SHOULD BE ABLE TO WORK SOME BUGS OUT, i WAS TOLD WITH THE G2 UNIT, I WOULD BE ABLE TO TAKE ADVANTAGE OF THE FLASH CHIPS OVER THE 2732 CHIP'S OLDER DINOSAUR TECHNOLOGY! i HAVE HEARD OTHER GUYS RUNNING THIS CAM IN THEIR TPI ON HERE, AND THEIRS SOUNDS PRETTY LOPEY,BUT MINE SOUNDS STOCK OTHER THAN THE CONSTANT UP AND DOWN CYCLING!!! damnit! IS THERE ANY WAY TO UP THE FUEL REGULATOR PSI, OR ADJUST THE IAC OR TPS TO HELP IT ANY FOR NOW?
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
No quick fix for your problem bro-
I have the ZZ4 and it idles very much like stock. I have 1 5'8 headers and a slp catback and dual catco converters. Once you put yor foot into it though it sounds beefy. your idle issue lies in the chip, way too much cam for the stock 350 chip, but my ZZ4 will run pretty good off the stocker chip, no funny business like you are experiencing other than the occasional cycling of the idle.
Re: TPI ZZ4 idling smooth, but hesitates??? HELP!!
Originally posted by hotrod85z....but It idles as smooth as the stock 305 I pulled out!! other than a cycling up and down every few minutes, could it be a vacuum problem?
I can't find any leaks,but at the intake manifold, I'm only getting 10-12 PSI of vacuum!
If you gas on it from a dead stop, and let off it will die! when you power brake it, and let off, it idles WAY down, then back up.
Between the MAF telling the ECM how much air it thinks entered the engine, and the O2 sensor telling the ECM how much actually did (with the vacuum leak caught in the middle), pretty much points to the reason as to why she's surging.
If you already set the IAC, TPS, timing and have proper fuel pressure (while throwing no codes), it's more than likely a pesky vacuum leak.
Car: 89 IROCZ
he's not using the zz4 cam look at his sig. it will run with that cam but very poorly
Car: 1986 camaro
Engine: 5.7 HSR
it is a zz4 camshaft, I had adgersmith mic the cam, it is the exact gm grind,but he said the duration is slightly larger, and BTW, tha lift is with 1.52 rockers
Car: 1986 camaro
Engine: 5.7 HSR
thanx fella, I've get the top end aprt doing some head work, I'll check out all of the vacuum lines and replace what I find cracked/leaking, G2 installed and the Burn1 is on its way, thanx alot for your help!!!
1 Post
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
The amount of duration in that cam will defenately give you an idle that the stock prom isn't capable of working with. Do you know what the centerline of that cam is? TPI set-ups don't like low centerlines at all. Not unless you have the capability to burn your own proms. But even at that 114-115 centerlines are best suited to the long runner lengths of a TPI intake.
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Originally posted by gmgod
224/236 is more than slightly larger than 208/221.
I wondered when somewas was gongi to say that . I have the setup bellow in my sig . With the stock 305 APYS file ....it idled fine . Now I am running a APYP bin and the thing surges at idle and stalls some time .....but has great throttle response etc. WIth the 3.73 gears outback and a 5 speed ..... it breaks loose from 2500 in second when I tramp on it ( brand new Kuhmo Ecsta 712's) Once I get the idle figured out , it'll be all good . great little cam for TPI I think ....glad I picked it
1 Post
What do you think a ZZ4 will produce hp and torque wise using a TPI (TPIS base/Edelbrock runners/modded plenum/stock throttle body) set-up. I would think a small loss of HP but some torque gains. Any thoughts? Will a stock prom run it?
Originally posted by Rob Wade.What do you think a ZZ4 will produce hp and torque wise using a TPI (TPIS base/Edelbrock runners/modded plenum/stock throttle body) set-up. I would think a small loss of HP but some torque gains. Any thoughts? Will a stock prom run it?
Car: 1986 camaro
Engine: 5.7 HSR
i believe the centerline is 112.5 the damn thing runs great once you get a little throttle to it, I have power braked it and got the car up to 90 MPH and let off the brake and it still spins until you let off of it, really impressive for a stock engine ,balanced, with a better cam!
Car: 89 IROCZ
Originally posted by Street Lethal
In my opinion, yes, the stock L98 PROM would run it... once you upped the fuel pressure, that is. Of course, it won't be near it's full pontential, but it will run it though.
Originally posted by 3.492rs.do u know how much to up the fuel pressure? i have the zz4 cam also
But again though, to maximize it's performance with the added lift and duration, burning a new chip is mandatory....
Sanjay
08-12-2015 03:41 PM
