083 and 113 flow rates
Old 05-24-2005 | 05:22 PM
fixin87formula's Avatar
Car: 1987 Formula T-top
Transmission: 5-speed
From what I have read the iorn L98's and the aluminum ones off of the vettes flow almost the same. Is this correct or am I mis-lead. If this is legit then would it be safe to say that a iron L98 head milled to 58cc's would give the same power gain as an aluminum one on a 305? Also I have read where people have said that they have gotten a 30 hp gain from doing an L98-aluminum swap on a relativly stock 305 (stock cam and intake just intake porting and bolt-ons). This seems extreme to me. I didn't think the 305 tpi heads (416's I think) were that restrictive.
Old 05-26-2005 | 12:35 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
If your car's an 87 you got 081 heads not 416's
Old 05-26-2005 | 04:16 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: 083 and 113 flow rates
Originally posted by fixin87formula
From what I have read the iorn L98's and the aluminum ones off of the vettes flow almost the same. Is this correct or am I mis-lead. ....
They don't flow the same. They are close, probably within measurement variability, on the intake side but not on the exhaust side. See the details in this thread, approx 2/3 rds of the way down in my summary post. The source for each of the numbers is listed either as a clickable link or otherwise cited in text. Ported flow data are also listed, along with their sources. HTH.
Old 05-27-2005 | 12:54 AM
Yea my cars an 87. Everywhere I read , I read that the 081's and the 416's are pretty much identical other then the 081's are centerbolt valve covers.
Pac J
05-17-2020 10:44 AM
Fireslash
04-11-2016 06:43 PM
LT1Formula
10-08-2015 08:34 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
dusterbd
09-29-2015 08:40 AM
Quick Reply: 083 and 113 flow rates
