release fuel pressure
Car: 91 formula
Engine: 350 tuned port. bolt ons
If I release the fuel pressure on my TPI by pressing the valve down won't it shoot gas all over. I want to replace fuel filter. What would you do?
pressure
Yep, I just dove under there and removed the filter, and let the pressure bleed off there as I loosened the nut, no big deal. Gas in the arm pit feels pretty good too just turn your head so you don't get any in the face. Larry.
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The easiest way to relieve fuel pressure is to pull the fuel pump fuse and then start the engine. It will run until 90% of the pressure is gone, then it will stall. You'll get a dribble when you loosen the filter but it won't spray in your eyes.
Car: 87 TA
Engine: 305 tpi
Transmission: auto
yes, pull the fuse and the gas cap, and let it run till it dies, then try starting it up a couple of times, and your good to go. just remeber to use flare nut wrenches($7 about at harbor feight) and put lots of anti-sieze and the threads and about a 1/2inch after the threads on the pipe itself.
by the way i tried taking off the cap on the fuel rail and the thing was seized, anyone know where to get a replacement cap and valve?
and for the orignal Q no it shouldnt shoot everywhere, just make sure you leave the engine sit for a couple of minutes,chances are your injectors are old and leaky and that should bleed most of the pressure off
have fun!
BM
have fun!
BM
Car: 91 formula
i hope it will losen because it is alittle rusted so i need flare wrenches. no problem
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
