MAF to MAP
Old 05-05-2005 | 08:32 AM
Crimson 383 cid's Avatar
Car: 1987 Camaro
Engine: 383 C.I.D.
Transmission: 700 R4
MAF to MAP
I was going to look into changing my tpi set-up to the MAP (from MAF)sensor but I was woundering if you are able just to swap throttle bodies or if the whole plenum needs to change???
Old 05-05-2005 | 09:56 AM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Judging by the way your question was phrased, I would do some homework before doing this swap.
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Old 05-05-2005 | 10:18 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
If you don't find the info you need on the Davis site (above post), then do a bunch of searches. There's more than enough info about doing the swap that you'll never really have a question that you can't find.
I just finished my SD swap.
But anyway, short answer, no, nothing really changes, a little bit of vacuum line, a new sensor, a jumpered knock filter connector, and maybe a missing MAF are all that will change under the hood.
Mark_ZZ3
05-24-2018 01:02 PM
BumpaD82
02-26-2016 02:57 PM
racereese
10-03-2015 03:46 PM
aaron7
09-30-2015 09:15 AM
Quick Reply: MAF to MAP
