cranks alot before starting.
1 Post
Car: Black 88 Iroc Convertable
Im having some starting problems. the car starts all the time. the problem is that is cranks more than it should before firing and when i does it fires rich. raw gas thru the exhaiust rich. if i pump the pedal a couple times while cranking it fires off faster than if i just wait for it to start. on a cold morning the car starts like it should. the cars a 88 iroc 305 tpi.
