Stock dyno results for a '91 Lb9 auto Trans Am....
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
187whp and 260wtq! I'm stoked. Let me know your thoughts, if there are any.
By all the replies, I guess this is either so incredibly awesome that know one can comprehend a reply, or..................this is the norm. So here are my questions.
1) I got 187 at the wheels for an auto, so that equates to about 230@ the crank. Aren't autos supposed to be around 210hp @ the crank?
2) If stock 5.0's have around 300lbs @ the crank, 20% drivetrain loss would put it at 240@ the wheels, right?
3) Why are my numbers higher than normal, or is this normal?
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
:shrug: Depends on the Dyno, depends on the tranny, depends on a few things. That's why 'k'no'w' one replies.
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
It's also hard to know how excited to be not knowing the correction factor used, or if 0 correction factor was used, what the weather was like. To many variables to get all keyed up over one dyno session. Now if you had another Lb9 car dynoed at the same time and you had more HP/TQ than he did, then you could be stoked...
1 Post
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Originally posted by SLP IROC-Z
good baseline! let the modding begin!
Car: 1999 Z28
Transmission: 6 Speed
Axle/Gears: 9" 4.11 Truetrac
i will when its back together, its gonna have stock TPI, stock heads, stock short block and just a mild cam.
![Cool](https://www.thirdgen.org/forums/images/smilies/cool.gif)
My first mod besides getting the AC hooked up properly and SFC's, will be a rear end swap. I'm tired of losing races to cars with similar hp/weight ratios because of my crippling 2.73's.
Thanks guys!
Thanks guys!
Car: '90 Mercury Grand Marquis GS
Engine: 5.0L Ford V8
Transmission: AOD
Axle/Gears: 8.8" Ford, 3.08:1
5.0L AOD Mustangs dyno those numbers. I thought all TPI motors made 300 RWTQ?
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
LB9's made anywhere from 275 to 300 ft lbs, and their big brother's made up to 345 ft lbs (& a mustang crippling 245HP).
Transmission: AOD
Originally posted by GOY
...their big brother's made up to 345 ft lbs (& a mustang crippling 245HP).
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
Transmission: AOD
SLP saw no future in the Camaro/Firebird and now builds Mustang parts. Happy with the 355 RWTQ, Kat?
Car: 1999 Z28
1 Post
Car: 87-Z r.i.p & 93-Z sold 99s-10
Engine: 305 TPI , 350 LT1, 2.2 4cylinder
Transmission: 700 R4, 4l60, ?
i got a 305 tpi stock...i ran a 15.4 in the 1/4 ...but i had a few beers all day, full tank of gas, bout 100 lbs of audio in the back, need tune up , alignment. So im guessin i still have potential to run better....my buddy's stang ran 15.00 with alot of mods https://www.thirdgen.org/techbb2/sho...hreadid=291860 i still gotta use that free dyno coupon
1 Post
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
