Best injectors for mild TPI
I have hedman headers, 3" exhaust and SLP runners. Nothing fancy, just wanna know what is a good injector that won't break the bank, I was thinking somewhere in the 28-30 lb/hr range so I can do some more mods in the future and not worry about changing injectors again. P/N's would be great as well. Thanks fellas
Will
Will
Car: 89 Iroc
Engine: 305TPI
I personally do not think that you need to go that large with a mild TPI. If you were planning on going to a 383 then maybe you should think about that large. You should be able to continue to get away with the 22lbers. The best would be to mod your car and the look at what it is doing as far as duty cycle to make sure you are not pushing them too hard and if you are upgrade at that point in time.
litemupp
Southern California Area
08-23-2015 10:09 PM
Sanjay
08-12-2015 03:41 PM
