TPI remote coil questions
Car: 87' IROC
What is the voltage that is sent to the ignition coil? Also i'm using this coil for testing purposes, which one of the four plugs is the power and groud wire? Can i just hook the power wire up to the positive battery terminal and the ground to the negative? Like I said, this is for testing purposes, it will not be in the car, i just want to run some tests.
John
John
With the coil wire toward you, the left pair of contacts, the near contact is for the pink switched power wire, the back contact is for the tach feed. The other pair of contacts to the right go to the dist. I guess the ground is to the case?
Fast355
12-02-2016 06:33 PM
Sanjay
08-12-2015 03:41 PM
