TPI set up on Chevy Vortec Motor
Car: 1991 FireBird Formula
Engine: 355 TPI
Transmission: 5 Speed Manual
what must be done to put TPI set up onto vortec motor, I was told all that is needed to be done is to drill a couple of holes in the motor where the manifold meets and tap the holes and everything could just be placed on??? Need more advice please
your going to need a new manifold base with the vortec bolt pattern.
Scoggin dickey- www.sdpc2000.com #12498060 400.00
edelbrock- www.edelbrock.com #3817
Car: '89 GTA
Axle/Gears: 3.45
yup, when using a tpi base on a non-centerbolt head (up to '85)you can do the drilling/tapping deal, but the vortech heads are too different. I've heard good things about the Scoggin Dickey Matt mentioned.
Originally posted by KiLLJ0Y
hate to tell you this.. but edelbrock made the Scoggin Dickey base..
same base..
same base..
The SDPC add is on page 1, behind the thermostat housing is the firing order. go to page 31. edelbrock announces the introduction of the NEW vortec manifold base. it says "edelbrock" behind the t-stat housing. different intakes.
Car: 1985 I-ROC
intake base
what about the vortec head is so different? The intake bolt pattern or the water jacket ports? just curious
Engine: 355 TPI
vortec manifold
I cant seem to find the edelbrock manifold? can you give me the page? Also would their be any disadvantages in just drilling and tapping the holes in the regular TPI intake manifold?
Car: '89 GTA
Axle/Gears: 3.45
bolt pattern is the biggest difference, and they get torqued to some ridiculously low torque (11 ft/lb's ?) and I think there's only 8 bolts iirc, factory intake gaskets are plagued with coolant leaks. I think the intake ports may be the same or close, but don't quote me on it.
I think the bolts are straight up and down too, been awhile since I've done a vortec intake and my memory sucks, lol
Car: 92' RS Camaro
Dude, Look at the HSR post just put up. THunder Racing is offering the Holley Stealth Ram for Vortec heads $45 bucks off list for TGO members in the month of march. $400 for a base? or $475 for the HSR for Vortec heads?
If you have to think on that one too long , hmmm.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Edelbrock made the SDPC base and I'm willing to bet $$$$ the "new"Edelbrock base is the same thing. Real easy to change a casting for the difference of a name or not :-) Or even leaving them and grindgin them off. happens all the time :-)
later
Jeremy
later
Jeremy
Yeah, the ZZ4 has GM castings, the 502 has Ebrocks though. It depends on the application. The 502 intake is exactly like the RPM too, but has a bowtie on it instead of Ebrock script. I don't know about the TPI vortec base, but based on GM's history, I can believe it's possible SD had Ebrock make the intake.
later
Jeremy
later
Jeremy
[IMG]tpi vortec edelbrock[/IMG]
Well, i tried to show pictures with the differences between the two manifolds, got the red X of death.
Originally posted by GTA matt
What is you guy's deal? The man asked which intake would work on vortec heads. I found 2 intakes that fit the bill and gave him the location. Then all of a sudden everyone is up my @**. What gives?[IMG]tpi vortec sdpc[/IMG]
Car: 92' RS Camaro
I highly doubt that SDPC even has the capabilities to manufacture let alone design a Base. They are a Car Dealership and they have a performance division that sells performance parts. Most of the parts with their name on it are Private Labeled and manufactured by other companies. ppl do this all the time.
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Originally posted by Cooper
yup, when using a tpi base on a non-centerbolt head (up to '85)you can do the drilling/tapping deal, ...........
If have early or late and want to use them on a cylinder head of the oppisite style all you have to do is slot the two center bolt holes on each side of the intake manifold. You have no drilling/tapping to to.
1 Post
Engine: 4.0L
You can't use a non-Vortec intake manifold on a set of Vortec heads because the bolt pattern is completely different and the ports are raises quite a bit on Vortec heads. They do not match up.
I should say it's difficult to use a non-Vortec intake on a set of Vortec heads, not impossible. You would have to be a skilled fabricator or know a buddy that is to pull it off.
Here's a picture of the port mis-alignment.
Car: '89 GTA
Axle/Gears: 3.45
Originally posted by John Millican
This is a totally incorrect statement. First off you can't tell the intake bolt pattern by the valve cover, you have to look at the heads.
Car: 1985 I-ROC
Just this last week we had an 87 monte SS in the shop that had what would appear to have the "new style heads" on it. It had center bolt valve covers...... but the intake/head bolt pattern was still the old style... Be careful, there are some heads out there with the new valve cover and old intake bolt pattern.
Fast355
12-02-2016 06:33 PM
Sanjay
08-12-2015 03:41 PM
