300 crank hp?
Old 02-23-2005 | 08:43 PM
350f_bird's Avatar
Car: 91 firebird formula 350 or 94 grand am se
Engine: 350 or 3.1
Transmission: 700r4 or what ever a grand am has
300 crank hp?
Can a dual cat TPI 350 make 300 hp at the crank with out porting the heads or putting in a cam? Is 300 hp possible with only bolt ons?
Old 02-23-2005 | 09:22 PM
brutalform's Avatar
I think you definately would have to do some porting and add a cam, and some intake and exhaust upgrades. These engines were designed rather well, and its not easy to pick up a lot of power with one or two upgrades. When modding these engines, your going for torque. Id have to say it will come real close on the H.P. though. But will not exceed it without extra mods. Headers and intake improvements, (bolt-ons) might bring it around 300.
Old 02-23-2005 | 09:28 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I agree with Brutal. I believe a L98 can get very close to the 300hp mark with only bolt ons, but it won't excede 300 by much without cam, intake and headwork. Torque on the other hand......
Old 02-23-2005 | 09:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Going by some of the times I have seen posted I would say yes. I recently saw a post of someone in the lower 13's with stock heads and cam. Some call them "factory freaks". Allen
Old 02-23-2005 | 09:44 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
I actully believe i am close to that mark. I haven't gotten it dynoed yet and don't want to brag until i can prove it.
Old 02-23-2005 | 10:18 PM
GTA Notchback's Avatar
Car: 88 GTA Notchback
Im not sure I have an 87 Corvette with TPIS ZZ9 cam, TPIS Big Mouth base intake, AS&M semi-siamised runners, 113 D-port heads with cleaned up runners, ported plenum, and true dual exhaust with no cats and on the chassis dyno assuming 20% loss for 700R4 I have 305 horsepower torque should be a little over 400 at the crank. I was hoping for more but cant complain as the exhaust and custom chip netted me aprox 30 horsepower at the wheels.
Now I just have to get a set of long tube headers and see where that puts me.
Old 02-24-2005 | 11:15 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Hey, I lighly ported/polished my heads, had headers, small (210/220)cam, and headers and put down 241 rwhp; which is equal to a little more than 300hp at the crank. It was untuned at the time too.
Link in the sig will get you to the dyno sheets.
Old 02-24-2005 | 11:37 AM
Mine dynoed at 254.3 at the rear tires which I thought would work out ot 305hp at the crank based on 20% driveline loss.
Old 02-24-2005 | 11:58 AM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Yeah, with a little bottle helping it out.
hectre13
Car Audio
26
03-03-2022 05:38 PM
RS Reaper
10-17-2018 07:52 PM
no green
01-09-2016 09:22 PM
Royal_Z
09-30-2015 08:45 PM
Badass355ciz28
09-28-2015 08:31 PM
Quick Reply: 300 crank hp?
