52mm throttle body???
Car: 71 z28
Engine: 383 EFI
Transmission: Tremec
I have a throttle body that has a arizona speed & marine top plate, it states 52mm. The bores measure 2". The throttle body says Rochester on it. It has an air foil attached. Is this just a stock t/b? 2" seems close to 52mm. Isn't stock 48mm?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
First of all, you got to be able to measure the bores alot better than 2". What is the bore to the closest mm? 2" is actually 50.8mm.
Second: AS&M probably purchases stock TBs (48mm bores) and then machines them out to 52mm and replaces the top plate. This is why the TB will have Rochester on the TB itself.
It is my guess that you have an AS&M 52mm TB.
Maybe this thread can answer your questions for you...
https://www.thirdgen.org/techbb2/sho...hreadid=277932
Terrell351
06-13-2021 01:13 PM
mdtoren
08-16-2015 05:45 PM
