TPI on a 383 stroker?
Old 02-13-2005 | 10:31 PM
wreckspert350's Avatar
First of all i must say i'm glad to have some knowledgeable sources to hopefully answer my questions, so thanks. Now here's the deal, i'm currently building a 383 stroker, my block #3970010 it's a 4-bolt main, using a 5.7 rods, forged eagle crank, forged eagle h-beam rods, and forged aluminum SRP pistons 8.0:1 compression (future turbo setup). I was originally going to go with an easy carb setup but i got to thinking i would much rather have fuel injection even if it costs me some extra cash. Well i found this deal on ebay
http://cgi.ebay.com/ebaymotors/ws/eB...e=STRK:MEWA:IT
and i was wondering what i would need to do to use this TPI with my 383, also this motor is going in a 3rd gen camaro. I'm currently using an early model heads (399899, 3998991) i've heard something about this setup not working with early model heads is this true? Well i think that's about all the information i can provide so far, if you can help me out with what i need to do to make this setup work, or if it can't work. Thanks for the help.
Old 02-14-2005 | 10:09 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have heard that there is a compatibility problem between early heads and the TPI heads, something to do with the angle of the center two bolts on each side.
However, I would never put a stock TPI on a 383, the stock TPI does not breath well enough for that many cubes. Heck, it even chokes a 350...
Old 02-14-2005 | 02:39 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Yeah, I wouldn't put anything from that auction on a turbo'd 383 except for maybe a few of the sensors.
mhatfield 14
10-24-2015 07:48 AM
Reddeath210
10-06-2015 08:20 AM
Mickeyruder
09-02-2015 02:45 PM
bdads
08-24-2015 06:01 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: TPI on a 383 stroker?
