Chip out of my piston
i got my motor pulled out, took the intake off, took the oil pan off and stuff, and in the bottom of the oil pan i found 3 chucks of metal...i was like uh ohh...then i looked further into it, and on the bottom of one of my pistons, it goes down into like a skinny taper piece, and that piece just broke right off...its on the very bottom of the piston, and it looks like it might not affect performance, but its still a concern...the cylinder wall from what i could feel had no scars or anythign on them....what do you guys think? its supposed to be a low mileage vette motor...do you guys think i should be concerned about this or what?
Car: 73' Nova~~~TPI Powered
Engine: 283 Cubic Inch Rev MUNSTER!!
Transmission: Turbo 350
Axle/Gears: GM10 bolt w/4.56 posi
uhhhh.....yeah!!! I would find out exactly what happened and fix this problem before you put the motor back in action. If you have peices of pistons missing, your motor will be out of ballance and it will prolly destroy itself causing total destruction. YOU DO NOT WANT TO RUN THE ENGINE THIS WAY. Trust me. You should replace the broke piston, flush the metal shavings out of the engine, check main and rod bearings and check for cyl scars or you will face worse problems when you get the motor running.
GOOD LUCK!!!!
Joe
GOOD LUCK!!!!
Joe
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
if you found pieces of metal in your motor, and it sounds like a piston skirt, youve got problems. pistons don't just commit suicide
yea its just part of the bottom, maybe its called the skirt....but there was just 3 little chunks that i pulled out of the pan, there was no shavings or anything which was kinda wierd...so your tellin me i have to replace that piston....how much do you guys think this will cost?
You can get a stock cast piston for as little as fifteen bucks. You really need to find out why the skirt broke in the first place, liek possible flyweight interference, or cap bolts stitting too high, etcetera. Once you determine what caused the problem in the first place, you should have a clearer idea of what your next step(s) is.
When that's all done, plan on balancing the entire thing. You can do it yourself if you have some equipment.
KO1
16
10-15-2015 05:00 PM
LT1Formula
10-08-2015 08:34 PM
