broke the shrader (SP?) valve fitting.... need info
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
as stated..
i think this the right place to poste..
what happened wasi went hulk on the poor fitting when screwing it in to the fuel rail. I snaped it clean forgetting it was aluminum. Do any of yo guys know what thred size it is on the fuel rail? im just goning to buy a 90* fuel rail to -6 an fitting for fuel pressure gauge and t'ing off to n20.
i assume the fuel rail is either metric or a NPT fitting any one know the correct size for sure?
thanks for any help..
any of you guys run a fp gauge and n20 from shrader valve? if so can you tell me parts used?
-T
-T
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
thanks for info... just kidding.. any one know size of hole in the fuel rail? i tryed to screw the remaindr of my shrader in to a 5/16 npt at autozone but it only went in a half a turn before binding.. any one knoow the correct fitting of the hole?
-T
all search posts about this do not lis t the size of the hole in the fuel rail..
-T
Hotrodboba400
12-10-2019 07:07 PM
