350 tpi timing
Locate TDC of the #1 cylinder on the compression stroke (both valves closed).
Install the distributor with the rotor pointing directly toward the #1 cylinder.
Arrange the secondary ignition wires on the cap in this order:
Set the base timing of the distributor at 6° BTDC.
Start the engine, allow it to reach full operating temperture, and check the base timing again to verify it.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
also unplug the est wire tan/white above blower fan motor before you set timing.
Sanjay
08-12-2015 03:41 PM
