very high oil pressure reading
Old 01-21-2005 | 10:20 PM
Karl1990's Avatar
Car: 1990 Pontiac Firebird, 1984 Camaro Z28
Engine: V8 305 TBI, V8 350
Transmission: AT
whenever i start the car, the oil pressure is at about 40. but when i start to drive, it jumps to about 60 or higher. i was driving on the freeway at about 70mph and the pressure was way past 60 and it was so high the needle couldnt really go any higher. its still the stock sending unit and all and i was wondering if its just the sending unit or something like that or if it's serious problem. the pressure goes down when i idle, but then jumps right back up. i was just wondering if you guys had any ideas and if this is a serious problem or the beginning of one. thanks.
Old 01-21-2005 | 11:09 PM
anondude13's Avatar
That's where your pressure is supposed to be... Not only that pressure is higher when it's cold...
Old 01-21-2005 | 11:14 PM
Karl1990's Avatar
Transmission: AT
yeah got that, but the gauge is reading way past 60, is it supposed to so far that the needle is bouncing because its gone as far as it can go?
Old 01-22-2005 | 08:43 AM
Blu91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
Try replacing your Oil Pressure Sending Unit. Should be just above the Oil Filter. That solved the problem for me.
Old 01-22-2005 | 12:02 PM
anondude13's Avatar
When I hooked up a mechanical guage, my car was reading up to 75lbs under load. I think you're fine.
89GTAOz
05-16-2020 09:31 AM
355sbcTPI
08-19-2015 04:38 PM
bamaboy0323
08-15-2015 07:20 AM
ChevyZ71
08-13-2015 07:30 AM
Quick Reply: very high oil pressure reading
