aHEAD of the game
Car: 86 Z28
Axle/Gears: TBD
aHEAD of the game
i can get a set of used l98 free need hot tank magnaflux new valves
or go find a set of vortecs: used 250-330 or new 460-600
which is the better deal for hp i will be using a stealth ram (in march mated to a low milage 350 with a mild cam(undecided on which but like xe268 suggestions welcom).
looking to make 350-400hp yes i know the vortec stealth won't be in till march or later
Car: 86 Z28
Axle/Gears: TBD
these should do for the camp cams xe268
http://cgi.ebay.com/ebaymotors/ws/eB...948368475&rd=1
if i'm wrong correct me
found a few aritcles on this setup xe268 will post links in case anyone needs them.
or maybe even this cam not large but ok it seems
http://www.sdpc2000.com/catalog/989/...c-Camshaft.htm
basically i would have the 330hp 350 HO with stealth ram
any comments/suggestions
Car: 86 Z28
Axle/Gears: TBD
articles i found
none with stealth but at least some ideas of performance
http://www.2quicknovas.com/vortecheads.html
http://www.carcraft.com/projectbuild/116_0403_mail/
not the 268 but is the next larger xe274
http://www.carcraft.com/techarticles/81998/index.html
268 and others
the danger mouse
http://superchevy-web.com/tech/0312sc_dm15/
268 and others
the danger mouse
ZZ3Astro
08-13-2019 12:57 AM
