what cam you think would be right 4 me???
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
can i get some cam ideas from you guys heres my set up
HSR
383 strocker
AFR 195cc heads
10.5-1 comp
holley 52mm tb
7730 ecm Will have custom prom
700r4 trans "probuilt"
373 gears
walbro 255 fuel pump
1.6 rr
hooker 1 3/4 long tube headers
mufflex 4" exh
currently running cc305 cam but i think i want to go bigger
I want it streetable but its not my daily driver
HSR
383 strocker
AFR 195cc heads
10.5-1 comp
holley 52mm tb
373 gears
1.6 rr
mufflex 4" exh
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Yeah well I got my cam with the intentions of later on getting a supercharger or a turbo wich will happen to be my next upgrade.
What are the all the specs of your cam ?
Car: 92 camaro
Engine: 383 stroker
i do like it jus looking for a change want to try something new you know "waste some money" lol
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
The GM847 would be a good cam, will be a little on the tame side with the 383 but if you want streetable...then it would probably be a good choice.
