Ceramic coated plenum and runners?
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
Has anybody done or heard of doing it?What benefits and or drawbacks would there be?I am thinking of port matching the base and runners and then having them coated inside and out.I'd like them to match the headers.
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
I think that coating the intake would be bad. The intake should be able to dissapate heat, but ceramic coating would hold it in. Cooler air means denser air, and that means a better, more complete burn. High volumetric efficiency= higher horsepower. If you want it to match, I'd recommend painting it to match.
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I don't know how much difference there is between ceramic and powder coating, but mine are powder coated and I really couldn't tell any difference after I had it done.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1986 Z28
That what I had originally planned on doing to mine but the guy that did mine said the chrome powder coat tended to yellow, because he had to clear it afterwards. I am kinda glad at with a different color (if black is considered a color)
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
My ported SuperRam plenum, runners, and intake were ll ceramic coated when I got them (already ported by then). he idea is to keep the heat out. Does it really have any beneift? I honestly doubt it, personally. I know the top lid still gets PLENTY warm.....
Car: 92 Z28
Engine: Boosted LSX
That guy would be right..! If you Dont clear coat a mirror silver or almost chrome powdercoat.
1. UV from sunlight will make it go dull. Over time turn grey.
2. if you dont clear it, and get grease,grime etc on it. Which all will happen. and You goto clean it. You literlly run the chrome particles outa the material and leave a black spot.
3.. If you clear it it dullls to a silverish look.
BTW that setup looks great. Who did the powdercoating.
Car: 1986 Z28
Thanks,
It was just some local guy at a sign company. He was one of those "good ole boys." Charged $50 for the plenum, runners, and all accessory brackets.
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Edit - I found your pics on your web site.....thanks...
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Black is a color and unfortunately black will either dissipate heat very well or absorb heat very well, depending on the surroundings. Obviously in the engine bay with the cooler air on the inside and warmer air/environement on the outside it's going to absorb heat, you gotta hate that!
Car: 2016 Camaro SS + ???
....unless theres something different in the formula of black power coat which I'm unaware of.
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Originally posted by onebinky
Another benefit of the ceramic coating is that since it is so smooth, it will prevent carbon buildup from forming in the plenum and runners.
Car: 2004 BMW 330Cic
Engine: 3.0
I measured a significant difference in intake air temperatures after ceramic coating my plenum and runners.
At the track between runs from heatsoaking when the engine is off and the car is parked my intake air temp would climb into the 130-140 range. After coating it would only get as high as 110-120.
There is a direct impact on performance from the lower temps.
Car: 1989 Firebird T-Top
I have talked to a company that does ceramic coating for many of the nascar teams. Believe it or not, the car will run a little cooler dispite with coating is suppose to do. I read some questions of it turning yellow. The only thing that will happen is a tarnished discoloration where the runners curve to the intake. This is caused by the bending of the metal to curve it, not the coating on the metal. Keep in mind that true ceramic coating is a process that creates a bond to the metal that permainate and cannot be just stripped off as paint or powder coating can. It leaves a finish that is paintable and in most cases, it will resist all the harmful affects of oil, antifreeze, brake fluid, etc. This is an excellent addition to any motor!
Royal_Z
09-30-2015 08:45 PM
