Whos got the baddest NA 305 TPI?
Old 03-08-2005, 01:06 PM
  #101
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
[QUOTE]Originally posted by SLP IROC-Z
[B]1989 IROC 305 TPI 5 speed
weight w/ me: 3350
mods:
free mods
headers
off road y
cat back
ac delete
emissions delete
ported plenum
13.952 @ 97.08 w/ 2.02 60ft on 205 75 15s, 35* air in oct of 02
Thats awesome! That gives me more hope for the 305 once its back on the road with it's new T-5
I also have:
headers
cut out before cat
ported TPI w/ SLP runners and Air foil and AFPR
ac and smog delete
1.6 ratio comp magnum rocker arms
And spohn LCA, SFC, Panhard rod, and LCA relocal brackets
Now I am pretty confident I can hit 13s' on a sticky tire and some computer tuning
Old 03-08-2005, 04:13 PM
  #102
TGO - 10 Year Member
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
without a doubt
Old 03-21-2005, 11:04 PM
  #103
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Ok, I just ordered all new valves, 1.5 for exhaust and I went up to 1.94 on intake. I am assuming that they had 1.84 to begin with so I will have to cut the seats out larger.
Is the 1.94 intake going to help or hurt my combo? I hope it helps because I just ordered them, my heads were also milled a little.
Here is what my heads look like now, can someone edit it and draw lines to help me unshroud the combustion chamber (if needed).
My motor mods / specs are listed in the very first post.
Thanks!
Attached Thumbnails Whos got the baddest NA 305 TPI?-c-documents-settings-mark.markspc
Old 03-21-2005, 11:34 PM
  #104
onebinky's Avatar
It'll help. 1.94 is about optimal for the smaller bore of the 305. Anything larger would have no to negative effect on performance and efficiency. Also, a +.040 305 is a 312, so you have a few more cubes than you thought
Old 03-22-2005, 12:02 PM
  #105
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Originally posted by TunedPort 335
1MeanZ-
Also, the Vette headed intake valves are 1.94"... which can cause valve shrouding. you probably already know but this is why many people shy away from building up a 305. You can get alot more flow with the bigger bore.
When you stuff that bigger valve in our small bores, the air/fuel has less room when going around the valve and into the bore. I think the 1.84's are actually alot more efficient.
Is that right, or is this right?
1.94 will fit, but are the 1.84's actually better.
Old 03-22-2005, 01:12 PM
  #106
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
mine is .40 over, so my bore is bigger, and I have done a full porting / blend job on the heads and bowl area. So I hope that 1.94s will work better with my combo, but do not know for sure.
What do you think, is this a good or bad or whatever?
And should I work on the combustion chamber to get rid of some shrouding?
Orr89RocZ
04-25-2016 08:28 AM
gta90
09-15-2015 04:00 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: Whos got the baddest NA 305 TPI?
