runs rough,rich and wants to stall
Car: 1974 k5 blazer
Transmission: th350
my TPI is running rich it smells of raw gas and will die soon after warm-up, but will start right back up. the idle is a little low and it wants to die. if i get on it and as i come to a stop it will die some times. any ideas?
this is a map tpi with no emissions.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Originally posted by Bri3212
Project. Do you know what it should be at WOT. Im getting 4.24 on the datalogger.
No vehicle speed sensor (vss) signal can cause stalls when coming to a stop.
