1989 camaro iroc wont stay running
Car: 1989 camaro iroc
Transmission: auto
I have a 1989 camaro iroc and it does not want to stay running sometimes. One day it will run fine the next day it will just stall out I've tried everything i can think of to fix it. Can anyone help me out?
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Well, you give very little info. What have you done to identify the problem?
How about a tune-up? Vacuum leak, low fuel pressure, bad MAF, bad dizzy, etc., etc......
Transmission: auto
I have put a new ignition module, iac, maf, new cap, rotor button, wires, plugs, ignition coil, fuel filter and alot more that i cant think of right now. What it does is you can be going down the road doing 55-60 and it would just cut off. But now it wont even stay running it will start right up then cut off like 5 sec. later but you can fire it right back up. It wont show any codes I've had it on the scanner so many times and it will say no codes found.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'll put 2 bits on a MAF relay being kaputs - or an ignition module, but I'd probably stick to the relays.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
What about the fuel pump relay?
Intermitent problems are the hardest to identify. You put alot of new stuff on the engine and this happens, very fustrating. I know its tuff, but keep after it.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Check your fuel pressure, it's possible that your fuel pump is weak and cannot maintain the higher pressures needed in the mid to upper rpm range. You may even need to drive the car with the guage taped to the windshield so you can monitor it.
I would also replace the fuel pump relay, and oil pressure switch.
Transmission: auto
I did replace the relay and checked the pressure when it was at an idle but not moving i'm going to try that this week, thanks
Car: Tree Huggers
Engine: Do Not
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
Fuel pump died on mine last winter, it was a no go. Also, what the hell is a 'dizzy', second time I heard that term... I'm in the dark, sorry to say
Bill
Bill
Car: 2004 Pontiac GTO
Transmission: M12
You have to be kidding me... I replaced what I thought was the MAF Power relay (it said bosch on it, so does the MAF, my thought process) but what I really replaced was the driving lamp relay. DOH!!!! I'm going to the parts store now and getting that relay!
Thanks for posting that pic.
Transmission: auto
thanks for the pic that helps me out alot. Otherwise i was going to take them off one by one and check them.
Car: Tree Huggers
Engine: Do Not
Thank Vader for the Pic. I always find it with Search because he posts it up a whole lot. And his bay is cleaner than mine.
Engine: L98 350 TPI
Being a novice, I may need to check my fan relay, got a pic and some tips? I've only bothered with the dash fuses/CBs
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
