For a TPI swap, need MAF. which cars have one i can use?
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I'm swapping to TPI, bought the complete setup just doesnt have the MAF sensor....
As it is i'm running low on funds, so spending 100+ dollars on one isnt my first choice. What cars/engines can I get a MAF sensor off that will work with the TPI on a 350? Thanks,
-Chris
-Chris
lol, hey, sup?
the bird is down at Chickens shop by now (left here on a flatbed at...5:30?ish)...
I'm buying the setup from white91formula
Thanks dude
-Chris
Thanks dude
-Chris
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Must be a bosch from the cars listed above. The exception is the aftermarket sensors. I have no experience with these. Used bosch units are out there.
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Actually, which TPI setup do you have that you are swapping to, like what year?
Because, there are MAP TPIs and MAF TPIs. So it depends on the ECM.
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Iroc8t8
08-26-2015 08:14 AM
NBrehm
08-25-2015 11:49 PM
1992 Trans Am
08-08-2015 08:16 PM
