Air intake Vacuums??? HELP!!! pix
Old 11-18-2004, 08:34 PM
watafo's Avatar
Car: Chevy Camaro Berlinetta
Engine: V6 2.8L
Transmission: Automatic
Hey guys, I just need some help with this, it is a 85 Camaro V6 173 TPI. The car is loosing power all the time, and I just found out that this rubber connector has 3 outputs, the purple vacuum goes to the ignition coil, and the green one goes to the fuel pressure regulator. How many vacuums should be there? I have only 2, what is the right way to connect them to this rubber connector? I think this is my main powerloss problem in my car. The middle output is the strongest one, if I disconnect it, the car stops or idle roughly, the other 2 ones do not suck so much but they need to be connected to the right component, and that is why I need your help. Thanks!!!!
Old 11-18-2004, 08:35 PM
watafo's Avatar
Engine: V6 2.8L
This is the other pic with the vacuums connected....no clue if they are in the right place.
Old 11-18-2004, 08:38 PM
watafo's Avatar
Engine: V6 2.8L
Another picture for your help.
1992 Trans Am
05-10-2023 07:19 PM
stalkier
12-06-2015 11:25 PM
kyle5647
08-15-2015 11:56 PM
Jake_92RS
08-11-2015 10:39 AM
Quick Reply: Air intake Vacuums??? HELP!!! pix
