Hey guys what size tire for a 16.5 10 inch wide wheel??
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: Hey guys what size tire for a 16.5 10 inch wide wheel??
16.5 ???
do you mean 16"
do you mean 16"
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Not likely to be much that will fit cleanly into a thirdgens' wheelwell. AFAIK, anything in a 16.5" size is gonna be for a medium-to-heavy duty truck.
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
haha this is out there huh.
how do you know it is a 16.5 wheel? did you measure it and what does it go on for a vehicle.
from my experiance.....16.5 rims are old truck rims med size the 16" is the tire inside bead seat diameter, the .5 is the anglke of the bead seat. so the rim has a 5 deg angle to seat the tire on it.
now if you measuring a camaro or bird wheel with a tape or something try again there is no 16.5 car wheels.
when measuring rims dod not include the lip on the side of the rim only the bead seats or flat spots..
jeff
jeff
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
