How much fuel can a -6AN supply? 454 SB related
Engine: 7.4 L of Small Block Fun...
I started the dyno pulls on the SB 454 today, the fuel pressure starts out at 45psi and falls to 20-25 above 4500. I suspect its the pump, its a Mallory 60FI so I ordered a Mallory 110FI but I am concerned about the 6 AN fitting will that support the 500 hp range?
If I am calculating right the 60FI pumps 30 gph at 40psi, I think gas weighs right at 6.35 lb per gallon so thats 190.5 lb/hr, I feel I will have to be in the 260-270 lb/ hr range.
BTW, with one plug gas fouled and one cylinder with over .125 lash on both valves.. (Don't ask ) It made 475 ft lbs at 4400 rpm.
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I am not a fan of high pressure in-line fuel pumps. I have been through 2 of them. I ended up with a Walbro 255LPH high pressure version for $108 that installs in the tank. Very quite and very reliable. Just FYI....
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
For you setup, I'd run twin pumps, either internal or external with -6 feeds on both or -6 off of the pumps to a -6 to -8 T block with a singe -8 up to the front of the car split to 2 -6's..
Racetronix sells a twin Walbro 255 lph intank setup for about $200 or so.
A friend of mine with a 383LS1 and Nitrous is running twin walbro 340 lph on his setup just to be safe.
There are many combos for the fuel system just need to find a setup that is affordable and will supply enough fuel.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I made some research last week about pumps and lines...
rkrause made 700rwhp with a "kenny bell boost a pump" and a walbro 255lph in tank pump with stock lines on his LT1...
/N.
/N.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: How much fuel can a -6AN supply? 454 SB related
400 rpm.
400 rpm.
(on the dyno). I believe I went overkill on my fuel system, and could have saved some real money going a bit smaller. With the -6 at the rails and -8 under the car, and -10 into the tank, you can see where the price really starts to add up. A lot of guys are making the same power with less fuel system...Tom
Thanks for the input, I got a Mallory 110FI pump and fed it on the dyno with just a single -6an on one rail and the fuel pressure held fine even with my 32 lb injectors running at 98% duty cycle. Since this is not going to be an all out race setup I will stick with the -6an since it seems to hold the fuel flow fine for now.
I was really suprised that it would support that much flow.
Happy Holidays!
Happy Holidays!
Originally posted by Racetronix
There is no such thing as a 340L/Hr in-tank pump. The model is GSS340 the spec is 255L/Hr @ 300Kpa @ 13.5VDC.
Fast355
12-02-2016 06:33 PM
