58mm TB & 24lb injectors too much for stock 350 TPI?
Car: 1992 Z28
I'm going to finally get rid of my 305 TPI and drop in a stock (L98) 350 TPI. I know I need to get 350 injectors and was wondering if 24lbs is too much for the stock motor? Also, is 58mm TB too much for stock motor or should I stick with my current 48mm or get 52mm? If 24lbs injectors is too much should I stick with 22?
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The 24#'s are fine, you WILL need chip-tuning though or you'll run rich. The 58mm TB is overkill. The 52mm TB is overkill for a stock motor. Unless you plan on making over 400HP, then stick with the stock 48mm. If over 400HP, then go with the 52mm I'd say.
I got a 48mm TB on my 385 motor. I could likely benefit from an upgrade, but she runs hard down the track.
I also run SVO 24lb injectors, I run em at 56psi. No problem with fuel starvation at all, WBO2 tells that story. Running a 24lbs on a 350 will be no problem as long as you get them tuned in properly with the chip and fuel pressure.
Sanjay
08-12-2015 03:41 PM
