Anyone try L98 heads on a 305?
I am thinking about putting L98 heads on my 305tpi.
I have headers, comp cam, ported plenum and 8.5mm MSD wires.
Has anyone tried this?(Please don't tell me I am wasting my time on a 305).
What gains can I expect in HP?
Will I lose driveability in anyway?
Will I have to do anything else?(Chip work obviously)
LB9GTA
LB9GTA
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
You'll lose performance unless they are the aluminum L98s out of the Vettes. Those used 1.94 intake valves and flowed VERY nicely.
The L98 iron heads have the same sized valves (I thought) as the LB9 heads (1.84/1.5). They flow within 3cfm of each other last time I saw the tables, and those 3cfm were well within 2% of each other, and that's within margin of error.
You'll lose performance because compression will drop quite a bit. It will be mid-high 8s at best, from the 9.3 stock it should be on a 305TPI. Good for boost I suppose
the best 305 heads available are the ones you already have on the motor or aluminum L98 heads like i have. many guys on here have posted excellent 1/4 mile times and power numbers with ported stock 305 heads. there are also a small handfull of us running the aluminum heads, me included. these heads boosted my trap speed from 92mph to 97mph in the 1/4, and thats with my 2800 Vigilante converter. before the head swap my 305 had a 214/224 cam, ported intake, and edelbrock headers and went 92mph. i swapped the aluminum heads on with roller rockers, and using the same cam and intake listed above i gained 5mph which is about 50 horse, you decide what head is for you. but either ported stockers or the aluminum L98s are the way to go. see my sig for more details
One of my best friends RMK (One of the mods here) put Corvette Aluminum L98 heads on his 305TPI. Although this was at the same time as other mods, so the difference the heads alone made is impossible to tell. The car runs very well indeed though.
Don't the LB9 heads have 1.84 valves?
The cast iron and aluminum L98 heads have 1.94 valves. So the only difference would be lower weight and a little better flow with the aluminums??
Now that I have an aftermarket cam and headers, don't I need more airflow, and won't the heads give me that?
Is everyone saying that is is a waste of money?
LB9GTA
LB9GTA
Car: 1997 Corvette
Untouched, the aluminum L98 heads flow as good as "stage 2 ported" iron L98 heads if I remember right. I think they had smaller chambers too for increased compression as well.
I still think with those heads you'll lose more than you'll gain, and you'll get worse efficiency with the lower compression as well (decrease in gas mileage for a possible decrease in performance).
Car: 1997 Corvette
Aluminum L98 heads are usually over $500/pair if you can find them. You're almost better off buying a set of used aftermarket heads, and the same goes with any type of porting unless you do it yourself. My plan was always to port my 305 heads and put 1.94 valves into them, but I picked up a set of LT1 heads a while back that I'm going to use. Quite a bit of work to get them to work though, its NOT a direct bolt-on, but they were cheap.
......Get L98 aluminum heads?(What about $ for them)
Remember that I live in Canada...
Heres a link to Scoggin Dickey, they stock them from GM Performance Parts:-
http://www.sdpc2000.com/cart.asp?act...id=277&pid=147
Spefications as below:-
SDPC Part Number: 12556463
Manufacturer: GM Performance Parts
Valve Size : 1.940"/1.500"
Chamber Volume CC : 58cc
Intake Port CC : 163cc
Spark Plug Position : Angled
Spark Plug Size : 14mm
Spark Plug Reach : 0.750"
Spark Plug Number : RC12YC
They cost a whopping $469.25 each! Best of luck!!
Car: 1991 RS
Engine: 5.0
Milled means the heads are cut down to raise compression, whether or not it will raise yours depends on the volume of your heads compared to those.
Decked I believe means they are checked to ensure they are completely flat on the bottom.
i got my heads from a Corvette owner. i got the heads, cast aluminum valve covers, roller rockers, valves, springs, locks and retiners, and screw in studs for $600. they were already cleaned, all i did was have a valve job done on them which cost me $40 or so. the composite factory head gaskets were $50. for $40 i bought the Standard Abrasives head porting kit and gasket matched and smoothed the intake ports and polished the chambers. so for a total investment of about $750, i swapped aluminum heads on my car and gained very little low end, but the increase in midrange power was amazing. from 3000 to 5500 rpm this thing goes. i think my quarter mile time with the stock chip and single 2.5 inch exhaust speak for themselves. (and yes i painted them black so they look like stock 305 heads except for the angled plugs )
Also, the heads are milled down and zero decked. Does this mean that they would put the compression back up??
Can anyone help with these phrases?
LB9GTA
LB9GTA
Zero-decked has to do with the block...milling down the block so the pistons are sitting at the top, instead of down in the holes. Normally done to achieve proper/best desired quench area between the top of the piston and the flatspot in the combustion chamber of the heads.
I talked to the guy about the L98 heads I am looking at. He said that the compression on his engine with the heads milled and zero decked was 10.4:1.
So if I was to put a compressed head gasket on my 305, along with these heads, would I still lose compression??
Also, does my 305 engine have factory flat top pistons?
LB9GTA
LB9GTA
ambainb
04-25-2016 09:21 PM
