400 hp Superram 350?
Old 09-09-2004 | 12:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
How bout this superram combo
Quick question on a superram combo.
I searched alittle bit on this topic and heard low 12's. What power will this produce. I am hoping for 400hp on a 350.
superram intake-either edelbrock base or accel superram base.
Trickflow 195's cnc'd or possible AFR 195's. smog legals
LPE 219 cam or similar. Possibly a 220/220 custom grind .525 lift on comp cams extreme energy grinds. Or 224/230 comp XE cam believe the XE276.
ZZ4 shortblock as is.
With 64 cc chambers I hear zz4 compression is around low 9's to 1 ration. Good for me, but should I get it to at least 10 to 1 with aluminum heads?
Is the XE276 cam too big for superram? I hear some are running it well but about the exhaust duration split. Trick flow and AFR flow good as is on exhaust port. Trickflow being slightly outgunned by AFR. I like trick flow cuz a bit cheaper and different. since they flow good and I hear superram likes single pattern cams, should I stay away from the XE276?
Old 09-10-2004 | 02:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Anyone know? It should be close to if not over 400 I would think. Anyone have a combo like this and have some dyno numbers.
Old 09-10-2004 | 10:38 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I know BuckeyeROC (sp?) has a similar setup, L98 with AFR ( i believe) heads, super ram, and LPE 219 and he ran 12.17
Old 09-11-2004 | 01:00 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
go with the single pattern cam.. it will work fine with the afr heads..
i'd also bump the compression up 10:1 atleast you're going to have to lower the maximum spark advance in the timming tables on the prom otherwise you're going to have knock problems
Old 09-11-2004 | 08:46 PM
OMINOUS_87's Avatar
Several folks run that cam. Including me.
David 91RS/Z28= runs it on a 110LSA
OMINOUS_87 = runs it on a 112LSA
Magnum TPI =runs it on a 114LSA
All 3 cars trap over 112mph in the 1/4 mile. Full cars, full interiors, AC, etc...
So yeah, it is proven to be a real good power maker.
My combo:
383
SR/SDPC base
Etec-170 heads
276 cam
48mm TB
10.25:1
Old 09-11-2004 | 10:56 PM
rockind78's Avatar
My combo:
383
SR/SDPC base
Etec-170 heads
276 cam
48mm TB
10.25:1
Ominous, I thought you were running E-Tec 200's.
Old 09-11-2004 | 10:58 PM
OMINOUS_87's Avatar
nope, just lil ole 170cc heads
childs stuff, Edelcrap, garbage
as most people like to call them when beating the drum for AFR
$900, LOL
Old 09-12-2004 | 12:44 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
superirocz was running a similar combo prior to his turbo setup.
He had a 355 with the super ram upper and lower and trick flow heads. I'm not sure what cam he was using though. He was running 12.7 @ 111. I forget how much hp he made at the wheels, but he made 390tq at the wheels.
Hotrodboba400
12-10-2019 07:07 PM
IROCtometal
09-20-2015 11:08 PM
IROCtometal
09-09-2015 10:01 AM
Hotrodboba400
09-02-2015 07:28 PM
IROCtometal
09-02-2015 02:01 PM
Quick Reply: 400 hp Superram 350?
