ignition coil mounting
Car: 1989 Trans Am GTA
I'm picking up my GTA from ottawa this weekend. It just had the distributir swapped and is now running.
I sent up some mounting hardware that came with the coil. The mechanic couldn't figure out how to mount it. Where exactly does it mount again?. We took it off in a hurry and it was pretty damn dark where the car was at the time so we had to leave it.
I swear it came off near the firewall around the back runners but I couldn't find the holes and apparently the mechanic couldn't either.
I really don't want to drive down with the coil jumping around under the hood.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
there is a heavy bracket that should be mounted to the two rear intake manifold bolts, and the coil bracket mounts on that with two 10mm bolts.
KAM
KAM
92camaroJoe
08-13-2015 06:07 AM
