how far can i go on stock l-98 heads
Old 08-15-2004 | 11:03 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
subject says it all. right now i am running 13.009 at 105mph on stock l-98 iron heads. how fast can they go stock. im surprised i got 105 out of them, but if there's more i want it.
Old 08-16-2004 | 02:34 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
airfoil
AFPR
edelbrock headers
random tech cat
flowmaster exhaust
Is this all the performance mods you've done on this car? What else? If you got roughly 50-70 HP from the above, I'd say go play the lottery next and consider yourself lucky. And the answer would be yes, you can get more if you haven't done anything else.
Old 08-16-2004 | 03:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Don't forget the Accel ignition to light it up.
Not sure I would call an "air foil" and "flow-not-so-well-master" performance mods really.
There is a little saying that goes something like this: "Heads make the power."
Old 08-16-2004 | 07:17 AM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
wow, more than 1 whole second shaved off the stock time with only bolt ons....with only a FEW bolt ons. Dang, I really can't wait to start modding my car now. You have NO head work done whatsoever? I am sure if you port them out a bit, you'd probably see a relatively good gain.
edit: I would also like to know the limitations of a stock L98 head. I have a goal of at least a 12.99999999 et without digging into the engine at all. Is this possible?
Old 08-16-2004 | 04:58 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
sorry, forgot to list other mods. ive also upgraded to a tpis miniram, zz-409 cam, vigilante 3200 stall, 52mm throttle body, no cat converter, and the all important bfg drag radials. heads are untouched except for changing to the recommended springs for the cam. and i know im putting at least 320 horsepower to the ground to run that trap speed. so with a 15% driveline loss (more like 18% to 20%)thats still around 370 at the crank.
Old 08-16-2004 | 05:06 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Very nice times!!! What are you getting for 60'?
Old 08-16-2004 | 05:11 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
1.76 - 1.83 60 ft times. gotta love those bfg's
Old 08-16-2004 | 05:16 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
and I was going to post you had to have a vig! Either that or you were going to get a BS flag.
Have you learned to whip out your own chips yet? This is on the 92 right? You could get a little more just from a dyno tuning session, but you're due for new heads.
Old 08-16-2004 | 05:18 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Oh, and @ 105, I got something like 290 hp with a race weight of 3200. :shrug:
Old 08-16-2004 | 05:23 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
im pretty sure im close to 3500-3600 lbs. ive got power everything, a full interior, a/c that blows cold as hell and all aftermarket (and probably heavier) suspension components including the front sway bar. i havent tried the chip thing yet, but i do have diacom software and from what ive recorded, the tune is pretty much dead on.
Old 08-16-2004 | 05:39 PM
Mesix's Avatar
Car: '87 Trans Am
Engine: L98 (Corvette)
Transmission: M5
How about mine? The stock corvette aluminum heads.
Still learning about my car :P
Old 08-16-2004 | 05:45 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
i know for sure that stock aluminum heads flow about 15 cfm more than the iron ones. plus you got a bit more compression too. what that equals in power output im really not sure
Old 08-16-2004 | 09:39 PM
Tony89GTA's Avatar
Car: 89 GTA
I got nitto's
Old 08-20-2004 | 08:56 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
well when i see times like that am usually pretty skeptical, but i cant really talk, i am goin 13.9 with a heads, cam, and converter 305 with stock chip and stock cat back with flowmaster muffler, and i am sure some people dont believe me. sounds like the mini ram and the cam are good friends, as are the converter and slicks. i would imagine that you are at the limit with your heads however. but i did want to congradulate you on fantastic times for a stock long block.
theshackle
03-05-2017 06:37 PM
sweet_87_iroc
09-25-2015 10:01 PM
gta90
09-15-2015 04:00 PM
camaro71633
09-01-2015 10:24 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
Quick Reply: how far can i go on stock l-98 heads
