depth of LB9 oil pan
Old 08-15-2004 | 12:32 AM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
anyone know the depth of the oil pan on a 1988 LB9 motor? i'm getting a melling oil pump and pickup and need to know the depth for the pick up.
-GTAman
Old 08-15-2004 | 04:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I don't know off hand, but the easiest way IMO to find out would be to take a piece of wood, lay it across so it forms a bridge and drop a plumb line type thing and measure that.
The easiest way to get the proper pickup height that I've used is to measure the depth then loosely bolt the pump on and install the pickup. Place a thin layer of modeling clay along the bottom. This acts as the gap between the screen and the pan. Once you have the proper height, remove the pan, and ulitimatly the pump and pickup and braze the pickup to the pump.
BDR
11-07-2015 03:05 PM
abray1
09-14-2015 08:18 AM
timonator
09-13-2015 11:49 AM
FtrSpeedy
09-07-2015 12:11 PM
dmtz956
LSX and LTX Parts
09-06-2015 04:45 PM
Quick Reply: depth of LB9 oil pan
