tpi fuel pressure screws???
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
ok i have an 89 camaro iroc-z with a 350 5.7 and i got a new kit from accel which includes a new diaprham kit...how ever they didnt supply new bolts...and i had to ruin the t-10 tamper proof screws to get them out...ok well now im screwed i went to the stealership and there is not even a part number for the screws so maybe someone can give me dimensions or something what will work so i can have it in...
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Any good hardware store should be able to help you out. Of course I would normally just use my magic bolt box. I can always find what I need in it.
Car: trans-am
Engine: tpi
MY 86 TA tpi had a some kind of crazy metric 1/2 side very fine thread bolts that I could not find at any hardware store. I tried home depot, lowes, and 2 others. I wound up using a small pair of vise-grips to tighten my original bolts
Engine: 5.7tpi 350,
Originally posted by antoine
i may have some laying a round how many do you need.
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
I just went thru replacing my FPR screws. They are M3.5/.6 pitch x 12mm long. The local hardware store most likely won't carry them. The dealer won't list them separately either. I believe they only come with a complete FPR assembly.
Try a hobby store that sells RC cars, boats planes ...etc. They seem to carry the odd sizes. I orderd mine online from a local fastener supply. The shortest they had were 20mm, but I just cut them down to 12mm using a dremel. I went with stainless steel allen-head screws rather than the torx. The allen-head is much better.
Engine: 5.7tpi 350,
sweet thanks...i went to so many hardware stores they said that they dont fit a 3 or a 4 metric
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Just go to a junkyard and start pulling GM MPFI pressure regulator screws off (2.8L and 3.1L V6's FWD and RWD, and probably more)...
Engine: 5.7tpi 350,
i have a 89 tpi 350 5.7 thats the cap we are talking about...so i can use those screws???
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
