Need some help deciding which way to go
Old 07-26-2004 | 09:34 PM
Fastrucken's Avatar
Well me and a friend are about to swap a 87 Iroc 350 into his 90 GMC Jimmy. The engine came with everything except the computer. The 87 was orignally a maf setup and my I thought the best way to go about this would be to convert over to Speed density, but maybe now thinking about finding a map ecm would be an easier way to go. The only ECMs on ebay I can find on ebay are S/D, and this costs about 150 bucks worth of parts plus the cost of the ECM to swap in and I can't find a maf ecm any where. So my questions are which way is the best route to go... stay MAF and locate a ECM (any help would be great) or get a ecm off of ebay for a S/D setup?
Graham
Old 07-27-2004 | 12:18 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I'm pretty sure they are all the same except for the PROM, but I'm not sure. I do know I bought a new ECM for about $140 from Autozone for my 89 GTA with MAF. You should be able to get one at any parts store.
Old 07-27-2004 | 06:31 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
You get get a '730 off ebay, and a map sensor, then repin the harness for speed density. Problem is, the prom is gonna have vats enabled. You'll need to turn it off in the chip.
-- Joe
Old 07-27-2004 | 07:27 AM
Fastrucken's Avatar
Do I have to get a new connector or does the one from the Maf harness plug up? I have searched but couldnt find anything cut and dry. I read the web page from the tech articles but I know that guy wanted to switch back and forth and I think thats why he had a special connector that he used.
Old 07-27-2004 | 08:02 AM
anesthes's Avatar
Engine: LC9 , LT1
You need an extra connector. I'd just goto the junkyard and remove a '730 and the connectors out of any GM car. Order a prom and a moates adapter, and burn a chip.
-- Joe
Linson
09-25-2021 07:55 PM
RS Reaper
10-17-2018 07:52 PM
Bubbajones_ya
10-25-2015 08:01 PM
aaron7
09-30-2015 09:15 AM
92projectcamaro
09-29-2015 07:07 PM
Quick Reply: Need some help deciding which way to go
