Needin' Help
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yep,
Code 33 = MASS AIR FLOW (MAF) Sensor Circuit (Gm/Sec High)
Code 34 = MASS AIR FLOW (MAF) Sensor Circuit (Gm/Sec Low)
Code 36 = MASS AIR FLOW (MAF) Burn-Off Circuit.
Do a and you will find diagnostic troubleshooting charts that I have posted numerous times for both the TBI & TPI engines for all three of your codes.
Car: '98 Z28 M6 & '89 IROC-Z 350tpi
Not to be rude, I appreciate your advice, but the grand ole' "Search"(which I tried BEFORE I posted this) won't allow you to search for codes 33, 34 or 36 because it won't allow less than 3 characters. So any help in the right direction would be appreciated.
Thanks,
Rob
Thanks,
Rob
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay,
You just have to do is a search for "maf sensor & maf burn-off" and it will turn up more than enough threads to give you eyestrain for a year. BTW, you don't have to include the parentheses around the search words. I just included them for emphasis. BTW, you aren't being rude, you had a legitimate question and wanted an answer. No problem!!!!!!!
jbliljohn
11-10-2009 11:13 PM
